Just installed a brandnew 3.0L in my boat and while adjusting the initial timing and rpm, the hose with the cuffs came off the outdrive as to where there was no water supply to the motor. I noticed it seemed to be getting hot and found the problem. I looked at the gauge and it was near 250 on the dash. I put the hose back down on the inlets from where it had slipped off and water again was being supplied. Then the motor started missing and I found water in the number 4 cylinder and exhaust manifold. The oil also looks milky. Pulled the manifold and head to inspect the block as best I could. No signs of any cracks anywhere I can see, including pulling off the pushrod cover. I set the head back down on the head and it does seem to rock very slightly. So, did I warp the head, crack the block, blow the head gasket, or maybe all of the above? I have never had that happen before with the water muffs coming off, and I am bummed beyond belief that I may have screwed a brand new engine.
