I have purchased an older boat (1980) skipjack boat with a 290 out drive and basically no engine. It came with a block and heads, and most of the tin. I have the original carb, fuel pump, water pumps, alternator, fuel pump y pipe and other misc parts. I don't have flywheel, vibration dampner, main bearing caps, rods or rod caps. when looking up the engine identification, the block and heads are not the original parts, and I have determined that they are junk.
Unless you want to machine and line-bore a set of different main bearing caps, a bare block without them is useless!
So I am building a new engine for it.
1.... I am going to build a 383 stroker with good quench effect pistons with information I have found elsewhere.
2..... what should I look for in a block and heads
3..... that will match up with the accessories ie alternator bracket raw water pump bracket ect. any help or information would be greatly appreciated. Oh and it originally had a 260b.
1..... Keep in mind that the correct pistons will offer a quench surface, but also that the quench dimension becomes critical.
This involves a correct piston deck height and correct compressed head gasket thickness.
In other words, a quench style piston cannot perform unless the quench dimension is also correct.
2..... I'd go with a later cylinder block that is roller camshaft ready.
If you go with the GM Vortec cylinder heads, you'll also need the Vortec intake manifold.
Pistons cannot be selected until you have until you have decided upon cylinder heads, and likewise cylinder heads cannot be selected until you have decided upon a piston profile.
Take a look at this thread beginning at post #7.
3..... The 6.2L (std 4.000" bore/ 377 cu in) or 6.3L ( 4.030" bore/ 383 cu in) are built upon the 5.7L cylinder block.
The stroke for either goes from 3.480" to 3.750".
Minus the harmarnic balancer and flywheel, all previous 5.7L brackets and hardware should fit.
BTW, your AQ series drive requires the 153 tooth flywheel.
If you buy a stroker rotating assembly kit, purchase the 153 tooth flywheel with it.
The cost to build this up from a bare block will be far more than just buying a crate motor from our host.
Any crate engine will be fitted with the dreaded GM style full dished pistons.
Honestly I'd tell you to find a boat that's in running condition. Nothing free (or cheap) ever turns out to be in the long run. I would hate to see you spend thousands on a boat that will be worth only a thousand bux, or worse, nobody wants at any price. Sooner or later you'll want to buy another boat, so pick your projects with an eye on resale value.
If you proceed, try to find a duoprop lower for the 290. That will greatly improve the value along with the "user experience"
I do agree with you on this.
If he builds a good Q/E into this stroker engine, he'll want the 1.78:1 ratio.... not the 1.95:1.
Here's my take on boat ownership.
Quite frankly, boats are rarely investements, and are almost always expenses.
No rule states that these are investments nor that we must get a good finacial return on the day that we sell.
A good attitude to have is in understanding this.
If not... you should probaly not be a boat owner!!!!!
Take the total cost of your boat project... from purchase to restoration completion.
You will be satisfied in knowing what you have... and there is a value to that.
Take the number of outings, or years of usage (or use your own formula) and divide this into your total cost.
There is your cost per outing or per year of ownership.
Example:
$20K spent on purchase and restoration.
You enjoyed 10 years of relatively trouble free use.
Minus fuel, that's only $2K per year.
If you and your family enjoy boating, what else can you do as cheaply?
Plus.... who better will know your boat than YOU?
