rainbow988
"Hello again, I had a chance t
"Hello again, I had a chance to pick up a 1996 30hp Johnson really cheap for a parts motor( has saltwater corrosion here and there) and discovered the lower unit is seized but the pistons and walls look awesome the motor turns fine all else on top looks like new.The lower unit on my 1989 matches up perfect, gonna do some swappin out.
I am changing the gaskets on to exhaust, head, water jackets. The smaller screws that hold the outter cover broke off in the head. I was able to remove the head no problem and now have it sitting here with 3 broken off "studs"
Can these be retapped if I romove them with a drill bit? Can I soak the aluminum head in some thing to free them up? ok to use heat? Is there a good way to flush out the white oxide build up inside?
Thanks alot this board is priceless for a home garage mechanic ."
