Hello all, just finished a rebuild of my 1988 60hp vro. Vro removed. So after new cylinder walls and piston,rings all was looking good. Also new water pump. I have a issue not sure what is causing it. Motor starts great, idles fine, put it in gear all works move throttle to first point get about 1300 rpm but that's it any more than that it boggs and dies. Now if I keep hitting the primer it will run but no more than 1400 rpm with WOT. Timing is set fine I believe. Also it I pop the carb plates in neutral it will rev no problem. Inhave also unplugged the temp sensor no change. Thoughts?
