Hi there,
I am looking for some guidance on wiring between the alternator/solonoid/starter please.
The Loom has cables labelled-
SUPPLY (Red)
??AT (Brown - large gauge) Took a photo and annoyingly i cant see what the label says
Tacho (red/white)
Negative (Black)
Start (Blue)
IGN W/LT (Pink)
Oil Alarm (green/Red)
Oil (Brown)
Temp (Green)
Purple/white???
The Alternator is labelled B+. B-, W, D. and the starter solenoid has 2 spade connectors at the bottom, which i thought the Supply and Start would go, although not sure which is which. Along with the Negative to the Batterys (connected in photo). I have the Main COM Positive connected from the main switch into the side of the starter
Any guidance would be appreciated.
thanks
SUPPLY (Red)
Tacho (red/white)
Negative (Black)
Start (Blue)
IGN W/LT (Pink)
Oil (Brown)
Temp (Green)
Purple/white???
thanks
