I have a Mayfair 2270 750GPH b
I have a Mayfair 2270 750GPH bilge pump along with an Atwood auto float switch mdl 2000. with a 1992 Mariner 75Hp. If I flip the switch on the dash to turn on the pump manually it will not work. (It did last week) I jumped the switch and it still doesn't work. If I lift the float in the float switch the pump does run fine. There is power to both. (Is the float switch bad) Or if not what is? Also there is no power to the dash switch.
Ron
Ron
