Have a BFP15P XRTA that is overheating at idle. Replaced thermostat, jacket and impeller. Still overheated. Seemed like not enough flow from the water pump. Pulled lower unit and water jacket -- connected garden hose to water tube and water came thru clean with very low water pressure to make sure there was no blockage.
Started pulling the water pump housing off since it's that last piece. Manual says to pull housing off but it will not move up more than an inch to the notch for the impeller key before a solid clunk from somewhere along the shaft. Since the motor is the extended shaft, it has the housing with the needle bearing. Is there a step to be able to pull the housing off?
Realize that it was a mistake to think there was anything wrong with the housing but the seals look a little rough and it looks like I'm going to have to replace it now.
Jack
Jack
