I’m totally new to this guys so please take it easy on my lingo. I’m not a mechanic and don’t know much about this boat at all . My problem is I have a 2001 bf90a that is running on 3 cylinders. I did the drop
Test (removed plug wire one at a time while running #2 made no difference when I unplugged spark plug wire)
Other 3 cylinder drastically changed idle or caused engine to stall. Checked for spark and appears to be firing same as other cylinders, ( removed each plug and turned over motor to get a visual of the arc between plug and block) also
When I pull each plug wire from plug while
Running I hear a loud clicking or arcing from the plug wire itself on all 4 cylinders. The arcing seems to sound the same and have the same rhythm. I removed the linkage for the choke and closed off the choke on the bad cylinder but didn’t get any response. ( I read that was a test to see if it was fuel
Or spark)
Compression was 182,177,180,180i guess my question is , should I assume it’s fuel related and have carbs rebuild or is there something else I can check to narrow down my problem.
I just got this boat. Only got to take it out one time. Wouldn’t go above 4k rpm wide open throttle at 15 mph (24 ft pontoon 5 people on board). Ran perfect until we pulled up to dock to load up. Died and wouldn’t start up. Any help
Would be appreciated
Or spark)
