jakepitsville
Hey to All.
Having few troubles with my Honda Bf90 1998/99 1400hrs. I noticed the engine was sluggish on acceleration and had stopped idling properly -by this I mean it took 10 to30 and would slowly lower from 2000rpm.
so I overhauled the fuel system. The fuel filters were a bit dirty so they were replaced and fuel lines were flushed. The carbs were drained and were clean. The carbs were then pulled off and cleaned with spray carbie cleaner ( I could not get the jets out - they were stuck in there - Is there some trick removing these). The choke was reset/cleaned Everything was reassembled, The pilot screws were reset to 2and 1/4 turns and the outboard took abit to start but started ok. Idle was reset to 1000rpm. On snapping the carbs acceleration was better but the engine would not return to idle as. It was also noted that the diaphragm was not moving - I removed the dashpot valve and it was also noted there was no vacuum or air movement what so ever coming from the acceleration pipe. This pipe was cleaned and is no blocked
Help.
Also was noted some smoke from prop exhaust on deceleration after hard acceleration. In a car this would most likely mean valve stem seals - is this the case here???
any help would be greatly appreciated
Help.
