brianallen
My gear oil is leaking from one of two openings in the gear house near the gear oil check screw (see the photo). I reviewed a set of shop manuals to determine the likely source, but it doesn’t contain my exact model (I have a BABU1000054).
I was not able to determine which hole the oil came out. I am guessing that these holes allow water to drain. Somehow oil is getting into this area and likely allowing water to get into the gear oil.
Does anyone know where these holes go inside the gear housing? My guess is the one near the edge drains the water area around the shift rod.
