BF75 - Broken Grounding Wire
That's a "bonding" wire. It's intended to provide a path to ground for static and stray electrical currents that get generated as the outboard moves through the water. It is supposed to help deter the galvanic corrosion that the current can cause.
You could make your own replacement or order it from www.boats.net
See item 7 in the link below.
As jgmo said it's a bonding earth wire & should be replaced if broken. Sometimes if the engine main earth wire is not making a good connection, the starter motor earth current(250 amps) when cranking will instead travel back to the battery via that bonding wire & cause it to melt & break due to the high current which it's not designed for. So check your battery earth cable. The other possibility is that the bonding wire was snagged on something which caused it to break.
Bob
