Noticed this for the first time today, beeps with a pause in between and it only happened when running full throttle, when I brought it down to idle it stopped immediately. Couldn’t tell if one of the lights was on as the the plastic over them is weathered but my son said he thought it was the top which I believe would be oil pressure. Everything seemed to work fine, motor was peeing etc. This is on a 16 ft Carolina skiff (bought both last summer/fall), gets on plane fairly easy with top speed around 32 mph, but if the tach is working correctly it is running @5-6k rpm’s when at full throttle. Any ideas what would cause the warning and is that normal to run at such a high rpm at full throttle?
