AdmiralSteve
My bf50 has run fine with no issues until this spring. When I would turn the key I would get a faint 2 beeps as if the battery was low. The battery is fine and the boat started up but over a weeks time I lost power to the controller. After inspection I noticed the 12v pin on the lager green harness plug had corroded away. I removed the wire and hard wired it solving that issue, I thought. It worked one or two times but now in the morning I can’t turn the key and it will beep at me multiple times before it finally beeps it’s two times. The beeps are loud so it makes me think it’s getting enough juice. It would start before when it was barely beeping before. So it beeps a bunch and then ends with the normal 2 beeps and fires right up. I put it in gear and away we go. Everything seems fine. When I turn the key off and then try to start it again I get no beeps and it won’t start. But it will turn over just fine but won’t start. No beeps. The boat has never died after it’s started and last weekend it cut out and when I tried to start it again I got no beeps. Made it home and tried to start it up again and it was fine after sitting a couple hours. It’s almost as if there is a capacitor in there that isn’t holding a charge. I am considering hardwiring the harness as well after noticing corrosion on the motors main plug. Any suggestions are appreciated guys and girls. Is it safe for me to spray break cleaner or something on the plug to help clean up the connections without damaging plastics and rubber insulation?
