Shelldrake
Hello folks,
What a dummy......
Installing an external On-Off battery switch today and must have inadvertently let the cables touch. Smelled smoke and saw that I had fried the little wire that emerges from above the lower unit housing and is screwed to the motor frame.
What have I done? I assume that this is a ground wire for the electrical system? Is it critical? Have I damaged anything else?
The wire has disappeared into the housing, so I assume that the lower unit will have to be dropped to repair?
Thank you for any comments.
Matt
What a dummy......
Matt
