Well, thanks to guidance from hondadude and jgmo on cleaning my carb, my BF20 is running smoothly and well.
However, in my first outing on the water last weekend, I noticed an oil sheen under the running engine. I opened the case, and I saw raw fuel gently squirting from the float bowl edge each tine the accelerator pump did a stroke. The "o" ring gasket was extruding from the joint. This is a new OEM gasket this season.
I dropped the float bowl, and the gasket looked about 10% big for the channel. After a few hours, it once again fit. I've ordered another OEM gasket, but the swelling is troubling. I didn't get any carb cleaner anywhere near the gasket, but it was certainly exposed to gasoline!
Any ideas?
Any ideas?
