Recently i had the misfortune of flipping my boat. After allowing it to dry and airing out the cylinders with some wd-40 I troubleshot a ignition problem to the solenoid and replaced it with one i had. Now the motor runs fine starts great...however when i run a top speed it will all of the sudden just die. It will restart and run fine again. It is almost like a kill switch is being hit. It only happens when i am mashing the throttle. Suggestions? Is there a kill switch on the timing ring?. It is a 1989 40 hp vro Evenrude...E40TLCEC.
