"I have an 86 Alpha one 260 V8
"I have an 86 Alpha one 260 V8. It runs ok for about 15 minutes them when the temp gets to 180 or so. There is no water coming out of the block through the the thermostat housing. The leaves the Exhaust manifolds empty and the coupling catch on fire. I've put a new thermostat, water pump and impeller. I check with the engine hot if the impeller worked, i dose. There is plenty of water coming into the engine.
If anyone can help i would greatly appreciate it."
