I have a 1975 70 hp Johnson. Yesterday it ran, but only on 2 cylinders. Cylinder drop test shows number 1 cylinder dead. Swapped coils, same result. Replaced all 3 coils, power pack, and rectifier. Have 7/16 spark on all 3 but no start, just shortly after it ran for cylinder drop test. Removed and cleaned all 3 carbs and still nothing. Pumping fuel bulb makes no difference. Sprayed pre-mix directly into cylinders and still nothing. Have verified wiring several times to be correct. Plugs are wet with fuel. Plugs are new Champion L77jc4 gapped at .030. Nothing else has been changed. Flywheel key has been checked and is not sheared. Any suggestions would be greatly appreciated.
