"I've been trying to solve
"I've been trying to solve an overheating issue for two years now. My engine will start to overheat at high RPM.
I put clear hoses on to look for air and found lots when on plane.
I know, common problem.
I replaced the Hose fitting and gasket on top of the intermediate, didn't help.
I pulled the lower and replaced the Oring at the bottom of the pivot tube, Didn't help.
After pulling the lower and resealing, when I ran it on muffs water was pouring out of the intermediate housing below the fitting and gasket I replaced last summer. Not out of that seal but down below it.
I'm thinking its sucking air at that same point.
What has happened to cause this? I read one thread that refered to worn bushings around the pivot tube causing the tube to move up and down?
Please guide me to the repair before I drill a hole in the hull and go thru hull intake!!!!"
