robert_caulder
"I have a AQ151A on a Sumerset
"I have a AQ151A on a Sumerset houseboat that is over heating. So far the things I have checked and or replaced are as follows. On the raw water system, the water intake on foot has been cleaned, strainer was clean, impeller replaced even though the impeller I removed was only one year old and in execellent condition ,oil cooler was removed and checked, no cleaning was needed. The only thing I have not checked on the raw water system is water flow through the exhaust manifold. Can I, and should I remove the hose between the exhaust manifold and the exhaust yoke to check for water flow through the exhaust manifold?
On the closed (freshwater system), I have replaced the thermostat and ran the engine with the radiator cap off, to make sure the new thermostat and water pump were functioning properly, they are.
Other information and observations: I have not noticed any water in the oil so I do not suspect a blown head gasket. I plan to run a compression test on the engine this weekend to confirm this. When starting the engine and placing my hand on various engine components, the first part of the engine that gets to hot to touch is the exhaust manifold by the number four cylinder.
My boat is on a small lake in central SC, most are powered by outboards, and no volvo penta dealers are nearby. Any advice given would be greatly appericated!
Thank's
Robert"
Thank's
Robert"
