Aq140a fuel pump
dusher
"what should the fuel pressure
"what should the fuel pressure be on an aq140a, having problems keeping it running???
any help would be greatly appeciated"
i think they have a 350 fuel p
i think they have a 350 fuel pump on motor is it the same pressure???? the problem im having is it will idle fine but when i gas it up it will bog down and die???
"Then, the problem is likely t
"Then, the problem is likely the accelerator pump being stuck or improperly adjusted, or not working at all."
