"#1 What is the cross referenc
"#1 What is the cross reference number spark plugs in NGK, Autolite or Denso?
#2 Can I upgrade the little solex carburetor to a slightly bigger one without much mods? If so can you tell me to what.
#3 where is the thermostat? I have a closed heat exchange system that uses coolant.
#4What is the working temperature of the engine cooling system (in F) and what is the Max before getting to overheating?
#5 My throttle lever requires a lot of effort to move forward and backwards but it's easy in neutral. What can cause this?"
