"here I am again, installed an
"here I am again, installed an electronic ignition in a aq131 and went to start and it wouldnt. Realized I wasnt getting fuel (sparks good), accelerater pump was just dripping and half the gasket was gone between the base and the upper unit. So I rebuilt the carb new gaskets, accelerater pump and mixing screw.
I can get it started runs for a little bit and dies. I havent been able to time it cause I cant get it running long enough allthough at I did get a strobe on it for a minute and it looked about 10 degrees off and bouncing around quite a bit.
I have the carb set to 2 turns out on the mix and 2 out on the idle.
I'm having to stay on the throttle to keep it goin, getting some poping out of carb and my exhaust manifolds getting really hot when I seen the boot on the exhaust manifold start to smoke I figured I better ask for help.
Sorry about the long post, not sure what to do. Its my first boat and it ran before I started screwing with it just kept dying till it was warm and started sputtering the last time I took it out. Please point me in the right direction here. I'd like to get it out on the water"
