"Hello,
This problem has b
"Hello,
This problem has been nagging me for the last 3 years. Engine runs great upto about 4000 rpm and above that is starts to bog, stumble. I have done all the obvious, carb rebuild, compression is good, new plugs, Sierra fuel pump , Pertronix unit, check dwell, check advance springs, check distributor shaft play etc. Everything checks out OK. I know this is definitely fuel related. I am thinking fuel pump. The boat did not come with an external fuel filter, I installed that. The filter creates more resistance and I am thinking that the pump cannot supply enough fuel, which is why it will only run for 5 to 10 seconds above 4000 rpm until the fuel runs out and then stumbles. Throttle down abit and it runs great.
I know I can test for this, but that would involve getting another fuel line, cutting it to accept a pressure gage, and taking it out on the water to load the engine up and check the fuel pressure. It is easier just to buy another fuel pump. Or another idea, there is a plastic spacer between the pump and engine block, are these available in different thicknesses? Reducing the thickness of the spacer would increase the stroke of the pump resulting in more fuel.
Thanx for your suggestions and have a great day
Rob."
This problem has b
"Hello,
Rob."
