I just purchased my first boat a few months ago. Here is the history, - the boat was stripped of all the interior, motor started but would die out. First thing I did was spend a bunch of money refinishing the inside, not the best place to start. I was able to get it up and running, worked out on the lake for a few hours and I brought it home. The next day it over heated, bushing went bad on water pipe in out drive. I replaced the hoses bellows, all the seals along with the flange not it does not overheat. When it did it boiled over around the heat exchanger cap and soaked everything in antifreeze.
I took it back out everything worked fine ran great for 5 hours. Put it back in the water the next day and it would not start.
This is what I have tried. I replaced the distributor cap, rotor, points, condensor, and put in new spark plugs. My ignition timing is set the points and are gapped with a dwell meter. I was able to get it started after several hours of leaving the throttle wide open, in case it was flooded. My valvle timing is 6 -7 btdc, but it does bounce around a little.
it ran in a tub for about 30 min with cold water flowing in, I thought it was fixed, went this morning and it would not fire up. I took out the plugs they were heavily blackened. the carb has fuel puddeled in the bottom. I pulled the plugs, left the throttle in wide open and after a few hours it started. When I shut the motor off I do not see fuel coming in from the accelator pump.
I am at a loss, sorry for the long post, I read all the other similar ones, and it seems each one could play a small part in mine, last thing once it is started for the next couple hours it will restart will only small hesistation. any thoughts would be appreciated.
Thank You
nick
Thank You
nick
