AQ125A Engine Adjusting Idle
"Got Closer today adjusting th
"Got Closer today adjusting the idle of the engine, where it idles around 1000rpms. Though it sounds rough and additionally when i go to take it out of neutral and drop it into gear, the engine will die here. What exactly do i need to adjust to get it tuned correctly?
Thanks!"
"For starters, getting hold of
"For starters, getting hold of a copy of the Seloc manual and following the instructions for adjusting the idle mixture on Solex carbs as well as the ignition timing."
"Hey El Pescador,
Was look
"Hey El Pescador,
Was looking at that last night when i was tweaking with it. For setting the ignition timing, I haven't ever really grasped how do you set that?"
You need a timing light and ch
You need a timing light and check that you have 10º advance BTDC at idle (900-1000 RPM) and 36-38º at 2800 RPM. Seloc explains how to do it.
