"Can you please explain, my en
"Can you please explain, my engine is a AQ125A
I replaced the timing belt,plugs,wires,points condenser,but when i removed the distributor I did not mark the initial placement of the rotor and distributor. Now my placement of the distributor is in a position where I cannot put the hold down bolt into the engine. What can I do to realign the distributor with the bolt. I have the engine running now , starts, dwell is ok, idle etc., only I am in the wrong position with the housing?"
