rick_gregory
"Installed new Hot Spark. Star
"Installed new Hot Spark. Started right up running smooth but after a minute or two start to cut out or bog down and dies. will start right back up after it dies. can't keep it running. If I give it gas will die. but will start right back up. Already replace coil bosch blue, Put carb kit in, new cap and rotor. Also reset timming to about 10 degrees. Could it be the fuel pump? Help"
