Hi ,
My knowledge is basic++ - just getting into boating and having fun
- bought boat with 75 2 stroke evinrude
-2000 HP50 4 stroke installed
-princecraft 18.6 foot boat
-original evinrude 75 tach
- bought HP-0243-001 http://www.ebay.com/itm/161131128624?item=161131128624&viewitem=&sspagename=ADME:L:OU:CA:3160&vxp=mtr
It appeared to be running dble the revs, knowledge increased to the concept of 'poles'. Max rpms went above 7k
Based on this info - should have a 6 pole tach
http://faria-instruments.com/site_manuals/IS0012u.pdf
This post lead me to believe there was a switch in the 243-001 part http://www.marineengine.com/boat-forum/showthread.php?290603-Honda-tachometer --- I started to wonder if my honda tach was the wrong one given the double revs.
I took it apart, not easy/ probably a bad idea but I was curious..... and there is a little slider switch but i had to peel the bevel off. The boat reads 1.5/1.6 rpms at idle at the lowest when I play with the internal switch. There is no obvious 2,4,6,10 pole type switch in it. (see photo below)
I looked at the original tach and there is a circle switch to show 'poles' and it was set at 6. I read this and thought I should just try and use the old tach http://forums.iboats.com/mercury-mariner-outboards/tach-question-4-stroke-2-stroke-470254.html
It revs at 800+/- at idle, seems good.
I have no idea about props, other than the motor was on a pontoon boat then I bought an oem honda prop 283/330 mm basically a 11 pitch. They seemed similar. The boat will rev out to max on the old tach on both the orig and oem prop at 4k. Even when I get the prop spinning 'beyond' where its cutting/pulling into the water it still max's out at 4k.
So I know I should get an rpm meter...or....I dont have easy access to help or more gear.
Ideas?
1. Which tach is right? the old one set at 6 pole with 4k max or the new honda reving out past 7k. It sure seems at idle the old tach right.
2. from there I will need to investigate the proper tach, probably less pitch given the boat is slightly underpowered....not sure? how does one guess on the next prop as I have to buy to try.
3. If a motor prop stops pulling water (cavitation or whatever the term is), should the motor rpms max out and the motor cut out with the rev limiter?
thanks
(see the philips plastic screw, it modifies the rpms by about 500 rpm - the lowest I can get it is 1.5k which seems to high based on it being almost at stall level)
Ideas?
thanks
