You should have a full 12 volts going in. The following may be of some use to you.
The 1971 100hp model has ignition points.... and the setting is critical!
Point Setting Of Battery Capacitance Discharge)
Ignition Models - 1968 thru 1972)
Some have points - Some do not)
(Joe Reeves)
The points must be set to .010 but no wider than .010..... BUT in some instances due to a possible slight inaccurately machined crankshaft lobe or a slight offset of one set of points, a setting slightly less than .010 would be required as follows.
Whether the crankshaft has two or three lobes, when setting the points, check the setting of the points on each individual lobe by rotating the crankshaft by hand.
You may find that setting one set of points to .010 on one lobe, then turning the crankshaft to the next lobe, the gap measures .011 or .012 (too wide). This is where you would need to close that gap down to the required .010. A gap too wide can result in a ignition miss when throttle is applied.
Bottom line, pertaining to the point setting at the various lobe locations____ .010, .010, .009, is okay____ .010, .010, .011 is not!
(Battery Capacitance Dischage Powerpack Test)
Various OMC Engines - 1968 to 1972)
(J. Reeves)
Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. You might use a bulb of a somewhat lower voltage to obtain a brighter glow... just a suggestion.
Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire).
Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed.
Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
