G
Giles
Guest
" I have a 1985 Johnson 40 and
" I have a 1985 Johnson 40 and I dont think the alternator is charging enough. I have chainged the rectifier and that wasn't the problem. Can someone explain to me the checking procedure for the rest of the charging system? The motor runs fine but my volt meter (new) shows only a small amount of charge, maby 1/2 volt, with the battery somewhat discharged but still able to start. The battery is new. I also checked charging with an amp-volt meter. Under this low battery condition, how much should the alternator put out? "
