leg went up ok but only drop about 3inches when down button pressed,was slipped and greased 6mths ago.when it after 3'' of movement stops pump motor sounds like it does when leg is fully down, boat lives in the water 24/7. last worked ok 3 weeks ago,am going to marina to grease while in the water,then loosen the rear ram mount bushes,if unsucessful will have to slip boat again to check it out of the water,what else can i look for [damaged lifting ram internally,]there is only 4 swivel points on the leg that i can see,any advice would be appreciated barry
