When mooring this is a pretty nasty situation. Impact can be inevitable if I can’t restart the engine and reverse fast enough.
I’ve changed the throttle cables and idle air control valve with new OEM parts but the problem still continues. When the gear is shifted from forward or reverse to neutral, idle speed decreases and eventually the engine stalls. The problem exists even when the engine is warm. The idle speed and all other engine parameters seem normal. The engine is a 5.0 MPI on a Bayliner 2452. I thought someone on this forum might help. Your feedbacks are highly appreciated.
