"Hello Guys-
I have an ongoin
"Hello Guys-
I have an ongoing problem that I still haven't solved. Just a brief summary, it is a 1998 4.6 rwc w/ alpha one drive. Problem w/risers on stbd side running hot, engine does not overheat. The last advice you guys gave me was to check the impeller in the drive, possibly pumping enough water to cool engine, but not enough to cool risers.
Today, while running it on the hose,I noticed water leaking, but am not sure if it is normal.
On the front of the drive, just above where the lower unit bolts up, there is a oval hole in the housing, that is where I have water coming out, at all rpm's.
Is that normal, or could the water tube,and/or seals coming from the impeller housing be leaking, thus not supplying not enough water to cool the risers.
Thanks for your help."
I have an ongoin
"Hello Guys-
