"Harve;
I don't want to c
"Harve;
I don't want to create a huge issue, but I do have the following comments.
Firstly I think the engine RPM needs to be the reference constant, as most marine engines operate in the range of 650 idle to 4800 WOT; whether they are 4, 6, or 8 cylinders; 100 or 500 hp. Moreover they create hp more or less in proportion to RPM.
Heat generated is also basically proportional to hp generated, and therefor varies as engine RPM. The pump speed varies directly as the engine speed and this matches nicely the cooling requirements.
Agreed the lower gear set throughout is the same. The variable is the upper gearset.
A 135 hp 3.0L running a 1.94 gearset has a 20 tooth drive gear turning a 24 tooth driven gear, and the vertical shaft turns .833 rev per crank revolution.
A 330 hp 7.4L running a 1.32 gearset has a 20 tooth drive gear turning a 16 tooth driven gear, and the vertical shaft turns 1.25 rev per crank revolution; some 50% faster.
There is no way a 4 cyl 1.98 and a 7.4 L 1.32 lower shaft and gearset/prop is turning the same speed.
And would you mind telling me how the 7.4 pump is NOT going to be capable of pumping more water than the 3.0 at any similar RPM??
The fact is at any comparable engine RPM the 7.4 prop will be spinning about 50% faster than the 4 cyl, and it will likely be a 23, 25 or higher pitch prop due to the higher hp available, whereas the 1.98 will likely be a 17 or 19 pitch. This is all relative of course to the 7.4's much higher top end on similar size and class of boats.
In my post I mistakenly said the 1.32 will carry higher "torque"; I meant higher "horsepower". Any given shaft can of course handle only so much torque, no matter it's rotating speed. A faster turning shaft will carry more hp at the same torque since hp is torque times RPM divided by 5250. My apologies for this confusion.
But the fact is the 330 hp 7.4 simply makes too much torque for the Alpha regardless of ratio, and there have been lots of failures.
This much we can agree on.
Peace.
Rod"
