Alpha 1
howdy
I had a oil leak out of my low
I had a oil leak out of my lower case changed the shift lever seal and now I have a steady drip off water coming out where the oil was coming out.
"[b]"now I have a steady d
""now I have a steady drip off water coming out where the oil was coming out"
Ayuh,...
And Where,... Exactly,.. might that be,..??"
standing looking at the prop i
standing looking at the prop in the very front by the back of the boat where the lower half bolts up.
There are a few places where i
There are a few places where it could be leaking from. The seal in between the bell housing and the upper gear housing could be missing or shifted when you put the drive back on.
Did you separate the lower uni
Did you separate the lower unit? Did you disassemble the water pump? Did the water tube hit its mark in the upper gear housing? Did the water tube make it in there during assembly?
There are seals at the top and bottom of water tube. Missing perhaps?
Could be that the exhaust bellow popped off from the bell housing. (Not a big deal). Need a special tool to get the biotch on. I just bought it this week. Sure made the job easier.
