Accurate Anode Source
Nightops13
I have ordered 2 anode kits for my BF40 on line and neither has had the correct sizes. The last kit was close, but the two small zincs located above the cavitation plate are not right. Looking at pics on line, the zincs in the kit are for a larger engine. Looking for a source th at someone has had success ordering this stuff. We do not currently have Honda dealer close by. Thanks
Hi,
You didn't specify D or A model but there's a difference.
D model in link below. Items 19 & 20
Looks like the A model only has the trim tab.
Item 1 in the link below:
If boats.net doesn't list it then I don't think it's available from Honda either. They're pretty consistent about that. At least with the older models. I don't know about very late model stuff.
Good luck.
Forgot to say that, anodes are just blocks of cast zinc. If you're confident of the quality of what you've already purchased (I don't know how to test for that)
You could simply cut or file to fit if mount hole is correct.
You just need them to sit flush against the case.
Good luck.
