settimo velo
I'm looking into the issues of a twin V6 or V8 installation. Both the V6 and V8 will fit in the engine compartment. The main issue troubling me is access to the service items, particularly sparkplugs, and the oil and fuel filters.
I've noticed that Mercruiser moved the oil and fuel filters to the front of their engines, which obviously improves access. However, I'm looking for secondhand engines so I am trying weigh up just how much of a handicap this will be if I end up with older engines that have the oil filter down near the bellhousing!
If I fit V6 engines, I think I'll have enough room to get down in the engine compartment to reach right under the engine to change the oil filter. If I fit V8 engines I will not have the room to be able to do this ... I can squeeze into 13 inches but not into 8!
Then there's the sparkplugs. There'll be a 4 inch gap between the manifolds of each engine, so I'm thinking that I'll need access from the front of the engines, to reach down the sides to change plugs.
What do you think? Am I making this a bigger problem than it is in reality?
The project itself is on Facebook if you're interested in taking a look:
http://www.facebook.com/group.php?gid=179427293999
