the first thing i did when I got back with it, next morning, was test compression. 80 pounds all three cylinders. No deviation. Low compression, yep. But with the same across the board, which is strange, I might put it back together, put new plugs in and run it till it won't. I am deep enough that I could proceed pretty easy, but I don't have a manual, and there are a couple other things I am missing for a rebuild. I have no shop here, working on the motor on the back of the boat; have to build a table to hold the head, putting the pistons back in is gonna suck without clamps, and I want to go fishing. Kit for rebuild is 600 dollars. I can do it cheaper, I don't need the pistons, just rings and gaskets. Unless I find piston damage. I need to find someone who can bore or sleeve it, I have no idea where or who. Argh. And I have a bolt with the head broken off I've been working on for 2 days now. About a half inch of the threads showing. Holds the exhaust cover in place. Guess I will try to drill it out, wax and heat and pb blaster arent moving it. And I got cheap vice grips, cannot find my good ones, will go get a new pair that actually works and try them before drilling.
