"I finally decided to repower,
"I finally decided to repower, that’s the easy part. I have 2000 twin mercruser 350 mpi with 1500 hr. Both engines have been wet before, both have had valve jobs done on them at least once. Both have had complete exhaust manifolds, spacers and risers replaced 3 times. Two times with Mercruser and once with Osco. Osco the last time, infact 20 hrs. ago.
Now for my problem, the port engine has so much salt deposit on the new plugs that you can hardly see the contacts. And that is on both sides of the engine. Buy the way the engines are what they call a half system fresh water to the engine and salt water through the manifolds.
Is it possible the osco risers are sucking water back through the exhaust outlet? Oh I forget to tell you I also installed a Perco flush valve in line after the sea strainers. Where can the water be coming from. Is it the engine, manifolds or maybe the muffler system. nothing has been changed since 2000 when the boat was new. I have ZF 630A tranis, would it be wise to replace the engines (I’m thinking Crusaders) and using my old tranis. Any advice on the Crusaders any better than Mercrusers? Thanks in advance, this is a great forum."
