"running on one cyl.swapped sp
"running on one cyl.swapped spark plug still no spark,swapped wires to coils now other coil sparks.I removed green/yellow going to coil and attached test light.pull engine ,test light lights. Connect to other wire green/white(to coil) there is no light on the tester.I disconnected what a would call the magneto and got 2.69k ohms.I disconnected the ignition pick- up and got .776k ohms.The magnets on the flywheel both have magnetism. I do not believe it would be the pick-up or magneto as it does have spark on one cyl. anybody with ideas? how are the ignition modules on these things? thanks"
