'98 60hp Mariner 3cyl. 2 stroke
Blaine Rockey
My '98 60hp. 2 stroke 3 cyl. Seams to be stuck in forward gear upon startup. Throttle lever shifts from forward to reverse. Linkage at power head moves. Is the problem in the lower unit shift tang?
Remove lower unit again.-----Put lower unit in neutral.------Gear shift in neutral and re-assemble.-----You likely removed it in neutral and lower unit jumped into forward during the work.
Thank you for your help. That's what I did. Will check it out with the water muffs. Then it's off fishing with the grandkids. Thank you again, Blaine.
