96 Mercruser trim is stuck
da_king
"Pump makes noise with up and
"Pump makes noise with up and down and trailer buttons, but the trim doesn't move. It is stuck in the full up position. Any suggestions?"
if boat is used in salt water
if boat is used in salt water check hydraulic cylinders for salt build-up behind seals. if retaining ring is loose on shaft reseal caps. caps may need replaced due to corrosion. salt build-up causes binding that hydraulics cannot overcome through trim down circuit due to valving for "kick-up".
"Tim, I would open the hydrau
"Tim, I would open the hydraulic lines at the cylinders and then run the pump. It will bleed the lines a bit. Check to see that the motor is not stuck in the up position. Unbolt the cylinders and see if the motor moves."
