GarrenMedley
So I'm having a couple of issues. First off the engine seems like its only running on one cylinder. If I stay the engine and let it run it seams fine but once I give it some throttle it starts arcing from the lower spark plug to the cylinder head. I have replaced the coil, power pack, plugs, plug wires. Second off the starter switch won't shut the engine down. It will start it, but once you pull the battery cable and shut the key of it keeps running. Third issues is that if I'm running it and give it throttle the starter kicks in and won't stop.
Other parts replace
Used control cable
Plugs
Wires
Head gasket
Exhaust gasket
Power pack
Coil
Starter switch
Other parts replace
Used control cable
Plugs
Wires
Head gasket
Exhaust gasket
Power pack
Coil
Starter switch
