Hello! I have a '96 48SPL that lost spark last year. I ended up replacing the rectifier, Power Pack, and spark plug coil assembly (I needed it for vacation and just wanted it to work). It ended up being the key switch
It ran fine for the rest of the season (maybe 15 hours). Went to get it going this year for the first time. It backfired once, and then...no spark. I popped off the flywheel and saw that Sensor and Coil Assemblies had black melty ooze that had run down. Also, there was a strange almost gold looking dust on many of the parts. I'm going to replace the Sensor and Coil Assemblies, and probably the stator while I'm under there. Has anybody else had weird dust under the flywheel? There's a bit of lateral play on the plate, is the bearing underneath a wear item? I couldn't find any info on replacing it in the factory manual. I just don't want to smoke newly replaced parts. Thanks for your time!
I'll try to post pictures.
https://drive.google.com/open?id=0B-DRPSbcyD1tcWxscllGZU1xQkk
https://drive.google.com/open?id=0B-DRPSbcyD1taW9ld0ZwZEtSR1E
https://drive.google.com/open?id=0B-DRPSbcyD1tRTVvbjB2MTZuREU
https://drive.google.com/open?id=0B-DRPSbcyD1tb0hvd0I2Qm5YZk0
https://drive.google.com/open?id=0B-DRPSbcyD1tc29uQm9GWEl5Z1k
