96 57L 4bbl carb Thermostat
bill_k
"ok having a little debate wit
"ok having a little debate with someone, by changing the thermostat from a 160 degree to a 140 degree cause the motor to run hot."
"changing the therm from 160 t
"changing the therm from 160 to 140 will make the engine run colder, to cold for a V8 of that year and will require more fuel and not run as well."
Typically engines with "cl
Typically engines with "closed cooling" systems (the ones with heat exchangers) run 160 degree thermostats. It has something to do with the temp that salt crystalizes I think. Also Volvo penta's may use a higher temp thermostat then Mercruiser. Not sure what they use in Sweeden Or why? lol
