"Hi,I was having trouble shift
"Hi,I was having trouble shifting. I removed the control lever and found outer core of the shift cable was not holding. There is a plastic "bracket" of sort that holds the cable (which has a couple of circular grooves on it). It is broken or worn so that it will not hold the outer cable. Does anyone have the part number of this item or any ideas how I can fix it? thanks"
