Hope this is the right place to post this. I just joined. I have a 95 9.9 Johnson. It would sometimes pump water out if the teletell and sometimes not you could turn it off and restart it sometimes a couple of times. Till it started pumping. It pumped good water in neutral and in drive. No water would pump in reverse. I could run it wide open in drive with no problem. If I just slowly idled around the alarm would go off. So I pulled the thermostat out and also replaced the water pump and housing. It does the samething no water in reverse sometimes it will pump on startup if not you have to restart until it does. But now it will sound the alarm even if you are full throttle. It didn't do that till I changed the water pump. Any ideas would be appreciated. Thanks in advance
