94 johnson 200 hp venom inconsistent spark
Bowhunter3303
I have a 94 johnson 200 hp venom I bought from a guy and it is brand new and never been ran. It sat as a display till now.. I put it on my boat switch had a mercury before, and when I tested spark it's not consistent at all. Starboard side get more spark then the port which is almost none. I'm wondering if my power pack has went bad. I wouldn't think it would be bad just from sitting. Everything looks as if just came from the factory.
Update on issue.
I've changed the water pump
I've changed the ignition switch
And I've resistance tested the trigger and still have the same problem.
I'm thinking about just biting the bullet and buying a power pack
Not to say I'm a mechanic by any degrees or anything, but if I had to bet, I'd say the pack is bad. Johnson/Evinrude were known for them going bad, just as Mercury's were known for the stator usually causing problems. Kinda cool that you found a motor that old that was brand new!! Sweet find!! Good luck and keep us informed!!
