93 RUDE 150 INTRUDERCARBS CROSS FLOW
houtex
"DO THE PORT CARBS SUPPLY THE
"DO THE PORT CARBS SUPPLY THE STBD CYLINDERS ??
IF SO, DO THEY CORRESPOND TOP TO BOTTOM ??
TOP LEFT CARB TO TOP RIGHT CYLINDER ETC..??
THANK YOU FOR ANY INFO...HOUTEX"
"no,..the carbs,feed the cylin
"no,..the carbs,feed the cylinder,that is directly behind them....YOU have a 'looper'inducted engine.piston pulls fuel from behind it to in front passing by the sides.In a cross flow,fuel is pulled across,the piston,comes in on one side,exits on the other."
